I will be getting Comfortex motorized cellular shades. Switching to another brand is not a possibility as these met the household criteria of room darkening, available in TDBU and motorized, and affordable. They do not, to my knowledge, work off of either zigbee or zwave.
I was advised their remote frequency is 433.92, which I hope is accurate but cannot confirm.
My goal is to connect the Comfortex shades to the Hubitat. I've googled around, but would appreciate any insight anyone has on the below:
- The BondBridge can control devices in the 300-450mhz range, so it might work.
a. I know there is an official integration for the BondBridge to Hubitat, so that box is checked.
b. Does the integration require internet access or can it be all local wifi?
c. Has anyone connected Comfortex shades to Hubitat via BondBridge?
These controllers are $99 new, and about $75 on ebay. - The Simplicity Smart Controller is an add on for Comfortex. They have assured me I can add this later. This seems to be a third party controller that picks up the RF signal and sends it to the NeoSmart app via wifi, and seems to need internet connection and a cell phone. It is unclear to me if this device also picks up a bluetooth signal.
a. Is there a Hubitat integration for this controller? If so, is there any advantage to using this over the Bond Bridge? I was quoted $162 for this controller, but see them on ebay for about $100, so it is more expensive. - Some people use a Broadlink device to convert from RF into Hubitat via an unofficial Hubitat app. The Broadlink RM Pro has RF, and an app, and the app is required to set up the Broadlink. Installing the app requires access to many portions of the phone including contacts, so there is some privacy concern.
a. Will the Broadlink work without internet access or does it automatically upload to the internet whenever the phone connects to the internet?
b. Would the Broadlink hava any advantage over either the BondBridge or the Simplicity controller, other than price (at $44 new is it the least expensive). - It is unclear to me if some of the Comfortex motors have both 433 and Bluetooth, or if it is either or. If either /or, I am getting 433. If both, I might also have Bluetooth control, in which case I can apparently use an app on a phone.
a. Is there a Hubitat integration with the NeoSmart Bluetooth app? - Is there some other way to just convert from 433 to Zwave or Zigbee?
- Has anyone connected Comfortex to Hubitat and if so, how did you do it?
The operational goal is
a. Some shades primarily only raise / lower the top down portion automated via a set schedule to a preset location.
b. Some shades close via automation at night if they are open, but open in the morning only via a manual button press.
c. All shades can be controlled manually at any time, but the scheduled opening/closing functions will still execute if needed.
