I thought that hue, saturation, level, and temperature was how bulbs are set. But CT and RGB color modes have very different colors for the same values.
RM Rule (with no trigger, manually using the 'Run Actions' button)
Set color: Livingroom Light 1 ->Warm White ->Level: 75
Current States
colorMode : RGB
colorName : Orange
colorTemperature : 2203
hue : 11
level : 75
saturation : 20
switch : on
The color of the bulb look nothing like if I use Alexa to set the bulb to "warm white".
Modifying the rule to:
Color Temperature: Livingroom Light 1: 2200: 75
And running it toggles the state between these 2 values:
Current States
colorMode : CT
colorName : Sunrise
hue : 11
level : 75
saturation : 20
switch : on
Current States
colorMode : RGB
colorName : Orange
hue : 11
level : 75
saturation : 20
switch : on
The color output of the Sengled RGBW bulb (https://smile.amazon.com/gp/product/B073ZBYXKQ) drastically differs between the 2. Note that the color temperature, hue, level, and saturation are the same which I thought was how a bulb was set. The only difference is colormode and colorname.
Is there something I'm not understanding about colormode?
Additionally, if I change the bulb from using the 'Sengled Element Color Plus' driver to 'Generic Zigbee RGBW Light', the 'Color Temperature' statement above does not toggle between the 2 different states. @mike.maxwell Is this a bug in the Sengled Element Color Plus driver that needs to be corrected?
Bill
