I have my Hue lights and switch controllers imported into HE via CoCoHue, and they work wonderfully. I then exposed those devices to Alexa through the Amazon Echo Integration. All is good, except... Alexa treats the Hue Scenes as devices, rather than scenes.
Suggestion for the developer of CoCoHue... add a field in the device settings which will allow us to tell Alexa that the Hue Scene is indeed a Scene!
When I was using the UDI ISY994i with Alexa integration in my old house, the Integration not only allowed me to provide an Alexa invocation word or phrase, but also let me set the type of device if if didn't match the actual usage.
This is similar to how Alexa allows you to change a SWITCH to a LIGHT, if that is what the hardware switch controlled.
Any thoughts or suggestions?
Thank you
