I am moving from smartthings to hubitat. I have three CMARS bulbs that pair with hubitat but don't work correctly. They only think that works is flash. The on and off don't do anything, except when the bulb is flashing off will turn it off. Nothing else works. Are these bulbs just not compatible with hubitat?
Which driver are they using?
This might be helpful:
Thanks, I had tried that and it didn't work. I've found that changing the driver to something else then back to Generic Zigbee RGBW Light got it working. It's still a little buggy but I think I can work around it.
Whenever you change to a new driver, click configure. That may solve a lot of your issues.
