Can confirm the behavior. I had zero hits to the cloud from webcore since startup, then opened the dasshboard to see what happened. Instantly had 5 hits. Refresehed the page and had 5 more. Let it sit for a few minutes, refreshed the log and had 19. After closing the dahsboard, it quit growing.
My webcore version is supposedly the "local" version built in to hubitat.
The webCoRE internal app still uses an external UI (https://dashboard.webcore.co) solution to edit the piston and then push the psuedo-code back to the application on the hub. This was a holdover (maybe on purpose) from the SmartThings days. My bet even hosting your own UI (which you can), uses the external endpoints. Ugh.
