Is there a way to schedule reboots of the HE hub?
yep.... You can use hub rebooter or simply build a rule in rule machine.. I largely don't need this anymore but I keep it in place
What capability is the trigger under? I looked through the list but don't see hub information.
3 posts were split to a new topic: Cloud Connection unavailable
It just dawned on me that I use Eero for my mesh network (HE is hardwired to it... and Eero did an update last night. I have a IP reservation, but now I'm wondering if they're connected...?
plug directly into your router
I did the Eero update last night too, and I haven't had any connection issues (HE or otherwise).
I just have one Max 7 though (small house, so that's plenty), so I guess I can't rule out a mesh issue, but I'm still guessing your HE connection issue isn't related to that update.
Edit -- based on comments in eero's subreddit, it does seem like there's a possibility it's related to the latest eero update... I'm lucky my network's all fine, but numerous users are reporting unusual IOT device connectivity issues after this update.
I can it to connect when I do that. I went back to its normal setup, and did the network reset, but that didn't work this time.
Yeah... I'm seeing some of those comments now too.
You were right, it was an Eero issue. FWIW, if you turn the Homekit option in Eero off, everything comes back online.
Ah, good to know. I've never used eero's HK feature, so that's probably why I made it through unscathed.
