I have a C8 hub running platform version 2.3.8.118 which show "Cloud connection is unavailable".
I have tried all the suggestions from the FAQ and in previous community posts for this issue, but nothing seems to apply to my situation because I have not changed anything on the network or router. It just happened following a reboot earlier today. It now won't connect to the cloud.
The local connection to the hub works OK and all my automations are running correctly with Z-Wave or WiFi via the router.
I have Remote Admin, but this cannot connect from the Android app.
The hub has a cable connection to the router, which works fine for local connection from the app via WiFi.
I have static IP, reserved in the router. I don't have Alexa or any other hub.
Other symptoms reported in Hubitat logs:
- SharpTools io reports “connection refused” errors
- Attempts to send a Pushover alert give status: 408 Request Timeout.
- My routine ping to Healthchecks io also fails with status: 408 Request Timeout. Healthchecks io alerted me to the problem.
I saw one post that suggested trying to reauthenticate my hub to my account, but I am not sure I can do that while I have an active Remote Admin subscription.
Do you have any suggestions please?
