Yea, then you migrate, shut down the old hub, and reuse the reservation for the new hub. You are overly complicating it.
Register the Pro hub and see if you can migrate.
Ok I'll give it a try see what happens.
Ok you guys are right the back up does show. Question should I do a new back from the c8 with all apps disabled to prevent any cloud issue or just do a migration?
That was one of the things I pointed out as a suggestion.
Yes, cloud access to get the cloud backups will only be granted to the Hub once the hub is registered.
That is exactly what I did. I shutdown the C8, removed the reservation, then I went to the Pro entry, and added the reservation by typing in the IP of the C8. I shutdown the Pro, rebooted the router, and booted up the Pro which came back up with the IP of the old hub.
Thanks so should i disable any apps before the migration?
As long as the old hub is off and your new reservation matches the ip of the old you should be fine.
Thanks so do the migration shut down old hub change mac address for the static ip of the old hub in the router sound right re boot c8 pro?
All seemed to go well so far I want to thank all you guys for chiming in and helping with my upgrade great place again thank you. I did overly complicating it
If you read the instructions, all your wifi devices and apps should have been disabled.
Webcore specifically needs every child app Piston disabled under Apps, not just the main app. That is the only thing that burned me on my C7-C8 migration, as none of my pistons worked after so I had to restore them from a backup because I didn't pause them individually.
