Trying to clone a simple app fails and this appears in the logs
Anyone got words of wisdom?
Suspect there is a issue with your original app. Hi through it and check, fix any issues and click done. Then try again.
Certain that you are right but I can't see anything! It runs perfectly! It seems odd to me that the clone app crashes even before offering you the clone/export choice. In my book that makes it a bug even if this is the only rule that trips it
Will delete and recreate and test.
Do you have a custom driver in it?
It is the simplest app just checking the heating has gone off when supposed to!
Weirdly, started to investigate as discussed with step 1 being a reboot for a fresh start. Guess what fixed it
Kicking myself!
