Has anyone managed to locate a driver for this DI/DO unit? Have tried a couple of Hubitat Generic drivers but to no avail.
Regards,
Regards,
did you try generic zigbee switch?
Hi rlithgow1,
Thanks for the suggestion. Just tried it and although sluggish I can open or close the digital output relay. Problem is that I cant use the digital input that is available onboard. I need to monitor the input so I know when to open or close the output. I really need a driver that contains the switch output and ,say, the contact input.
Regards
Generic contact sensor not work?
