CLICK SMART+ 13A ZIGBEE Smart fused switch for bathroom extractor
Hi all
Im having a new bathroom fitted with two sockets on the outside wall of the bathroom in the hallway. One for lights and one for the extractor fan.
Ive already had the fan installed. Is it possible to use this to control the fan and also make it smart with my aqara humidity sensor.
Click Smart+ 13A Zigbee Smart Switched Fused Connection Unit [CMA30651] - £36.57 : Click4Electrics, Online Electrical Wholesaler
I'm using 3 of their 13A outlets and they are working well.
I've had no issues with them.
I assume this should perform just as well.
I have two of those one on my boiler and one on an immersion heat all work just fine.
I also have 6 of there double sockets 1 single and four of there scene switchs all working faultless.
Another option would be click smart 2 gang smart switch csp04 which you could use to turn on your lights and fan?
@garyburchell do you have click smart 2 gang smart switch csp04 working with HE?
I'm trying to find a 2-gang ZigBee switch for this purpose (Bathroom light and extractor) so fingers crossed :blush:
I dont have any of those. But they should work.
I don't have a separate switch for my extractor fan it works on a humidity sensors.
Just looking for some Uak compatible double sockets and came across the Smart + range. Did you have to buy the Click Smart + Smart Gateway Hub CSP010 to get these synched with HE? Or did you just add these devices as generic ZigBee switches?
I have single and double sockets.
Both joined direct to HE using this built in driver.
Generic Zigbee Multi-Endpoint Switch
They also work great and I've not had any issues with them dropping off my zigbee network.
Thanks @bobbles. I am in the process of moving all my devices over to a new hub to try and build a better mesh and I had loads of aurora sockets which kept falling off HE - so I'll try and use some of these Click Smart + double sockets instead.
If the generic driver works ok then I'll use that but is it worth asking HE to build a specific driver for these devices? Not sure if we can expose any more features or not but I'll take a look when I buy one :grinning:
I would be highly surprised if HE agrees to make a specific driver for a Tuya device, this is definitely not their favourite brand... :rofl:
