Chromecast integration TTS error: No signature of method: chromecastAudio.speak()
Hi, I have a Google Home Mini (GHM) and HE 2.2.7.126 (rev C-5).
HE managed to find the GHM, but when I tried the Speak option, it keeps throwing the following error:
groovy.lang.MissingMethodException: No signature of method: chromecastAudio.speak() is applicable for argument types: (java.lang.String, java.math.BigDecimal, java.lang.String) values: [test, 30, Emma]
Possible solutions: speak(java.lang.Object), play(), stop(), inspect(), every(), grep() (speak)
The command:
What do you think could have caused this issue?
Ps: I have setup a static IP to the GHM in my router too
Update:
I managed to find another setting; its a once-off voice change, but at least I can change the voice.
I went to Settings > Hub Details > Default Text To Speech (TTS) Voice
And the next time I enter the Text, it sounded differently :slight_smile:
Leave the volume and voice blank and try. I've never got the volume and speak to work at the same time, have to set volume independently
Thanks!
That resolves the issue.
One more thing, do you know how to capture current volume in GHM? I tried 'capture device' / 'poll devices' but no option to capture its current volume?
Never tried
All good, managed to create a RM that captures GHM custom attribute > volume and store its value in the global variable.
So that when it changes, the variable is updated too - so that I can use this variable as a comparison for another RM.
