Changing Device Driver For Existing Devices In The New UI
Good morning all,
In version 2.4.0.145 of the UI I am not able to locate where you can change the device driver for a given device. I have reviewed all the tabs. I would have expected the most likely place to be under the Device Info tab but nothing.
I installed a ZooZ Zen37 and it mentioned ensuring the most up-to-date custom driver is installed. That started me down the path of looking for the it in the new (and other devices). I can't located the drop-down selectable option to change the driver anywhere.
I am sure I am overlooking it. Can someone tell me how now change the device drivers in the new UI?
Appreciate it!
Don
It's the "Type" field on the Device Info tab.
OMGoodness. Somedays :frowning:
Thank you.
Think we have all been there.
Since the expected data in the field is to select the appropriate installed driver, which in the Development section is labeled "Driver Code," can someone please help me understand why the field is labeled "Type" instead of "Driver"?
Even if it were "Type (Driver)" it would be helpful and less confusing.
A guess: vestigial from SmartThings DTHs (device type handlers) ?
