Is there a standard way to change modes using Alexa?
I set up a virtual switch and mode manager which worked OK but it seemed to override the time based automation of mode manager. I was able to "Alexa turn on night mode" when I went to bed which worked great, but when morning rolled around and it should have switched back to Day mode that didn't happen.
I am not entirely happy with the way I do it, but I have a Rule that turnns off the Virtual Switch after a time. The mode change should stay in effect, and the Rule that changes the mode should not change after one itineration. (changes to) This allows other mode changing Rules to affects the Mode, including Mode Manager. I will take any help to making this Virtual Switch into a Virtual Toggle Switch.
HTH
Frank.
I can't find the source anymore (maybe it was replaced with a newer app?), but @Cobra had a "Switch Changeover" app that I use in combination with Alexa to set modes using Alexa and virtual switches. It just turns others in a group off when one is turned on. Unfortunately, the rest of my setup sounds similar to yours, so if the "mode change with switch change" thing isn't working for you, I'm not sure it would help (unless you aren't turning the switch off and back on again with a rule or app--I'm not sure if Mode Manager only listens for changes or if it fires the mode change in every "on" even if it's not a change).
Thanks for this, I had no idea the "auto off" existed, and that is a life savor for using Alexa Routines to trigger my switches. I wish Alexa could see "buttons" to make this even easier.
Thanks for the info. I have mine set up this way. At night the Night Switch switches the mode to 'on'. However, it always shows on? Should I add another rule machine that when Day mode kicks in, it switches the Night Switch off?
