I was setting up the new app on my iPad mini and I chose the wrong device . How do I switch the device to the correct device ?
On the main screen of the app tap your hub name and then switch to another hub. It may let you pick another device right from there. If you have another hub, switch to a different hub and pick a device there, then switch back and it should let you pick a new device.
Also can try to delete the app and reinstall it, then it may let you pick another device.
If none of that works you will have to go on the hub and modify the DNI of that virtual mobile device, to trick the app into thinking its gone, so it lets you pick a new one. Then once you get switched you can put the DNI back how it was.
When all done, whatever physical device is supposed to be connected to that hub device, you will want to "Select Another Hub" on that physical device and re-select it to be sure it is linked up properly.
Sorry I know all that sounds ridiculous but I tested it pretty good during beta and had the same thought of what if someone selects the wrong device.
