Hi all. I'm new to HE
I've been working with lutron, crestron, and other brands, but i'm playing with this lil boy at home.
I wanted to ask what options are out there for centralized panel lighting.
I currently have some fibaro and sonoff devices to control interior lights, but for outdoors i want to have them all at a power panel, controlled by a DIN-like device, like i do with the brands i'm used to.
What do you use?
What's currently out there?
Thank you!
@mail.martin Did you ever find anything?
I think the Shelly and Sonoff DIN rail modules are compatible. There are also Haseman (Fibaro) Z-wave DIN rail modules (though the idea of using Z-wave for centralized lighting seems pretty stupid). Sonoff doesn't take any switch input and Shelly will only work with line voltage input, so you can't really use low voltage keypads unless you use something like a Konnected board and program it though the hub, though in my mind that type of setup seems to prone to failure.
Hey.
Nope, i've never found anything.
I was looking for a more reliable wired solution, maybe something like control4 wired ethernet devices, but actually never digged any deeper.
