Centralite Keypad
I got one of these Centralite / Xfinity XHK1-UE keypads here I'm playing with.
I have the options set not to verify pin on arming. But it seems like the only way the arm buttons work is if you enter a code then press them.
Is that correct, or is there a way to do one button arming on these just by pressing the arm button?
I've always had to enter the pin with this keypad. I have an iris keypad that arms without the pin.
As @oldcomputerwiz says it requires a pin.
Iris V2 - Pin is optional for arming, driver verifies pin. Pin required for disarm
Iris V3 - Pin not required and not sent by firmware when arming, required for disarm
More than you may want to know about keypads at this link
