Looking to build a rule set to set the ceiling fan to low at temp over 70 to 75 set to med. 75 to 79 and high over 80. A bounds would be to temporarily pause the rule for an hour or a set time when the fan is changed at the switch (Inovelli Fan + Light LZW36)
Here is the rule I have setup for one of our fans:
If you use Rule Machine 5, you can setup a predicated condition that will stop the automation from functioning when a virtual switch is turned on.
You could have the virtual switch turn on with a press of any of your fan’s buttons using a separate rule, and then automatically turn off after the length of time you want (Ex.: 1 hour).
Let us know if you need help, and Welcome to the community!
Thanks for the reply seems to be working
Excellent!
Just a note that instead of adding “ELSE” and then “IF”, you can use the combined command “ELSE-IF”.
