We have Hikvision for the CCTV, in Configuration - Storage - Cloud I select Dropbox
The CCTV sends each movement up to dropbox.
My Question is how can I then pull that image into an image tile on a dashboard ?
View file
This is just a low res image for testing purposes.
Many thanks
Paul
The stream will need to have a viewable address. For instance on my Foscam feeds I use similar to this http://192.168.x.xxx:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=xxxx&pwd=xxxxx
So you will need to be able to see the specific feed in a browser window unless there is an API available you could tap into and pull from there with a custom driver
Create an image tile and put your dropbox url to that image in it. It should display OK. But unless you are able to overwrite a new image to the same file name it won't be able to show the latest image automatically.
That’s what I thought Angus, in the question above I placed a link to one image and yes, I placed that link into the image tile with a 5 second refresh but even without the refresh the image dies not show.
I have uploaded images to the C7 which do show. I don’t think it’s a firewall restriction as I have a weather tile that works well.
Paul
