Catch up after reboot
I noticed some lights that are controlled by HE were not on this evening. Discovered for some reason my C8 crashed.
Rebooted my C8 than had to manually turn on the various lights that should have been on.
Is there a way for the HE to "catch up" to where things/ devices/ lights should be at that moment.
I can't imagine HE could do it for you, e g. just turn on a setting to do it. You will need to build it into your automations and/or come up with a way to recover easily.
In RM I am pretty sure you can detect a system startup event, which may be useful.
You can create a rule that triggers st startup and does a refresh of typically problem devices.
