Hoping for some clarification about these two Caseta transition options... Are they related (do they stack), or are they independent/different (if so, in what specific way)...
These are only options for the dimmers (PD5-NE in my case), I notice neither is an option for the plain (on/off) switches. TIA!
That setting only indicates that Hubitat isn’t adding any additional setLevel() commands (over time) when the switch is turned off, over and above what is built into the hardware already.
Out of curiosity, what do you use for these values?
I'm sure I just left the "Turn on trans time" at 1 sec since that's indicated as the default, but I can't remember if the plain "Trans time" was something I intentionally selected as 1 or if that was also a default I just left as-is.
