Caseta Dimmer in a 3 way, Pico necessary?
Folks,
I like the look of the Caseta. I am asking if a wiring setup like a Zooz Zen 24 is possible. I would like to leave the mechanical "dumb" switch in place. Is this possible with the Caseta or is a pico needed to replace the mechanical dumb switch?
Thanks in advance.
Only Caseta dimmer working with dumb switch I know of is the Caseta dimmer pro.
Wow, wonderful and thank you!....but this seems like a pretty expensive dimmer switch.
It is. A Pico is $12 and you don't have to wire it. It also fits perfectly in a decora faceplate and matches the other Caseta dimmers.
:point_up_2: this, exactly. The Pico remotes are really great and help keep the look and feel very consistent across all of your switches.
