Hi all!
Trying to solve following problem:
I have a Zigbee plug that I use to turn on my car block heater each morning. I would like to automate that in a way that it would turn on every morning at 5:30. This is quite easy to do with rule machine.
Problem comes with following step. I'd like that I would have possibility to change the plug turn on time from Dashboard. For example, if one morning I'm leaving 3 hours later, the plug would turn on also 3 hours later.
In best case the timer would always reset back to 5:30 start time after plug turns off, so if I'm leaving at normal time in the following day, my car would still be warm early in the morning even if I don't remember to reset it manually.
Thanks for your input in advance!
