Is it possible to capture a device status and then restore it to another?
The use case is, I'm trying to get the outdoor light next to front door to turn green when the door is unlocked. When the door is re-locked, the bulb can't simply turn off, I need it to fall back in sync with the other outdoor lighting, there are a few possible states.
Ideas?
Just capture the bulb, turn it green, wait for event, restore the bulb.
I might try that, however the reason I didn't... it get's a little complicated. When motion is detected outside, the level of these bulbs increases for a few minutes, then returns to 33%. I figured the most accurate way would be to simply copy the state of another bulb to avoid any issues with things syncing back up.
without a way to copy and paste state, if I just return the bulb to white, 33%, worst case scenario is it takes a few minutes for the other bulbs to return from 100 to 33. Not perfect but not bad
You can copy the attributes of the "source" bulb into local variables in your Rule, and then set the "copy" bulb with them, like this:
I prefer @LibraSun 's method of using a variable for "normal" state....
I currently have a variable that is adjusted at select intervals to mimic circadian rhythm in my basement where there is minimal ambient light. I have rules that break the normal cycle (watching a movie [dimmed to 10%], game night [full brightness], etc). The return to normal condition is based on the variable value no matter what the previous state was.
