Capture Information From 3 Devices
[RELEASE] Advanced Climate Controller - A Commercial-Grade BMS for Hubitat - :construction: Developers / Vibe-Code - Hubitat
You might want to check out Advanced Climate Controller. It will log your cooling cycles, prolong them if your short cycling, and only notify you if you have an issue.
