Can't update hub
Hub Model C-8 Pro
Current firmware version 2.5.0.153
When I attempt to update to 2.5.0.159 the download fails.
I rebooted the hub and cleared the logs, but still no joy.
Suggestions???
Make a back up.
Roll back to last week or whenever you had no problems.
Download update.
You can try using the Diagnostic Tool to download the update.
Try going into network settings and flip from 100M>Auto or Auto>100M.
For whatever reason, it sometimes helps.
That is a good test as well.
Thanks for your suggestion, it did the trick. I switched to Auto-negotiate, and the update worked perfectly. I’ve been pulling my hair out for a while trying to fix this issue.
