I was creating a rule to speak if a window was open or a door was ajar if the heat or ac was on. I put in the contacts and the thermostat heating/cooling state as conditions. I thought about putting in a 3rd condition and selected switch accidentally and hit update to go into the list and select a different device as a condition, BUT, it will not let me select anything else. It is as if it is stuck on switches.
I saw this today too. I really couldn't remember if it had always been this way.
Had to remove and start again.
Bruce mentioned that in another thread. It did weird things when removing a condition - so either leave that condition and just don't use it in the rule (where you can do so), or start the rule over from scratch.
Ok, thanks guys. I will delete and start over.
