The dimmer is discovered by the HE hub as a Device, and can't find a a driver that works.
Looks like it paired correctly to me! Is this Hue's 4-button Dimmer? If so, switch to the "Philips Dimmer Button Controller" driver (click the big "Device" link you see in that screenshot, or go to the "Devices" list on the left and find this one, probably still called "Device" unless you labeled it; on the device page, under the "Device Information" section, look for the "Type" drop-down, change it to this driver, click "Save Device," and then hit the bit "Configure" button/command after the page reloads). That driver should work for this device.
