I've done some research here and google, but can't seem to find instructions from A-Z in my setup. Previous WInk user so my setup I'm trying to get is what I had before and working.
- My living room has no switch to turn on lights, and I have 3 lights, 2 cree bulb and a Lifx. I could tell Alexa turn on living room and all 3 lights came on. Now when I tell Alexa to turn on living room only the Lifx comes on, Via HE I created a Group called "living Room and under (Select switch for group) I'm wondering if I should set a Virtual switch there "but can't find instructions to create a virtual switch, but I figured I didn't need a virtual because I read members saying it can't be used for something physical.
Question: How can I get the group to show up in the Alexa skills to add it?
- Kitchen and dining room lights are all lifx and the switch to kitchen and dining are Lutron, before I can say Alexa turn on dining/kitchen or manually turn on dining/kitchen from switch, but if I turned it off from the switch, I could later say Alexa turn on dining/kitchen.
Now the issue is my switch has to stay in the on position in order for me to still use Alexa, if the switch is off, Alexa will tell me to check the connection and power supply because it's not responding. I never had this issue before.
Question: How can I get the lutron switch and lifx lights to all work again?
- Here's a list of my Alexa Skills
In my Alexa Device this is all I see and I tried Deleting the Alexa Skills and unlinking the hubitat skills for Alexa in hopes that it would re-discover
