Can't get into a rule-machine 5.1 App
Just noticed I can no longer get into one of my 5.1 apps
Are you on 2.3.0.113 or ???
Sorry.. That was stupid of me.. 2.3.0.113, C7. I was able to get into this on earlier 2.3.0 versions , though not exactly sure at which build it broke. Not a rule I change often.
Could you please PM me your hub id, I can take a look in the engineering logs on the hub.
I need you to roll back to the previous release, and then post a screenshot of the rule that is blowing up.
Thanks. It's blowing on the %WashMode%, because the variable is named %WasherMode%. It shouldn't blow up like that. But, now that I know about that, it's easily fixed.
Thank you kind sir.. I will fix that syntax error immediately :grinning:
Fixed the syntax error, and then rolled forward to .113. Yep, that solved it.
