Can't edit rule actions - Error: Cannot invoke method giveClipboard() on null object
I am on RM 5.1. I have a rule that I am trying to change the actions. When I click on the actions all I get is the following:
## Unexpected Error
    #### An unexpected error has occurred trying to load the app. Check [Logs]
   (http://192.168.6.10/logs) for more information.
I can't do anything else but click "done".
I have seen this on other rules recently also. I believe it has to do with switching "Publish clipboard" on and off and copying/pasting code from different rules.
Can anyone tell me how to clear this error so I can edit my rule now?
In my experience once that happens you just got to start over.
Now if it is a rule that has been around awhile you can create a backup and then load a recent backup where it was still working. Then export the rule and then reload your current backup and import the rule. That takes a few minutes to do but depending on how complex the rule is it might be worth it.
I have started doing a file exporting on all my rules about once a month so if this happens I can import just a copy of the rule without having to go through a whole restore.
If you can duplicate what causes the error you should make a test rule and report it.
Could you please take a screenshot of the Logs for the rule. It will show the error with a line number, and that would be most helpful.
I noticed that there was a new firmware version available, so I updated to it and the error went away. I don't know if it was the firmware difference or just the reboot that did it, but I can now edit the rule again.
