Can't connect through Remote Admin
Hello - I can login to remoteaccess-aws-hubitat-com just fine but when I click the Connect button it just hangs and I get a browser error. I'm not near the device but I had someone reboot it. No luck. Support?
Do you have a vpn setup to home? . If not recommend it . Usually built in to your router. If so you dont need remote admin you can jump on the vpn and use the normal hubitat local ip.
Tagging @support_team for help with the remote admin service.
Can you send me your email account in a private message? I can check to make sure your account is active.
Good news is that your Remote Admin service is active and operational. The bad news is that your hub has not been connected to the cloud in almost 2 weeks. Without a cloud connection the Remote Admin service cannot be used.
Thanks for the help everyone. I finally saw a picture of the setup and the issue was someone had removed the ethernet cable between the Hubitat and the router. :sob:
