I'm a Hubitat newbie. Got my hub going, figured out the dashboard, and added my first device. I have a Sengled colour bulb (which I factory reset) that is discovered, and I can change the dimmer and switch it on and off. I added a color bulb tile to the dashboard, and it shows me the colours I can choose, but if I select one, nothing happens. Is there something I'm missing?
Which device type is it using?
(You can find it from the devices list.)
It is a Sengled Element Plus
Model E11-N1EA, I have a C-7 hub running 2.2.5.123
If the type in HE is listed as "Sengled Element Plus", I think that driver doesn't support colors.
You might try going to the device page and changing the type to Sengled Element Color Plus and see if that works for you.
@tony.fleisher that was it! Thanks so much for the quick response.
