Can't add Matter Device Using Code
Updated C8Pro hub to latest 2.5.1.142.
Wanting to add a Matter Outlet just like several others I have added in past.
Paired to Apple Home, no problem. Put in pairing mode to add to HE. Using Web interface. Enter Code. Start Pairing Button stays grayed out. Tried several times, no luck.
In Addition the OR is right over the pairing code entry field which makes it a little hard to see.
Can you post a screenshot of that please? Also what browser/device (desktop/mobile) are you using?
This is going to sound strange.. But look above at the WiFi portion.. Even if you are commissioning directly, which can be done now, it wants to make sure it has stored WiFi info if the device needs it..
I had tried entering the WIFI info before and it didn't make any difference. Tried it again and this time it seemed to work. Never had to enter that data before. Gonna try another device to see if that makes a difference.
Here is a screen shot of the OR button on Chrome.
Oh... I see that from your screenshot.. Will have to investigate..
New to 2.5.1.. You can now directly commission WiFi devices without a phone or external Matter hub..
Yea.. Not good.. Will need fixing..
Which is good, but the reason this one I pair with Apple first is a lot of the time I control in manually and I use Home for that. I know I could pair it with HE first and then to Apple, but usually do it the other way.
Tried another one and since the WIFI info was already there it worked. Sorry for the bother.
not a problem.. Glad it’s working now
This is the best update for years
With the latest firmware, which is the preferred method to add Matter device to both HE and Home.
  1. Pair to Home, then pair to HE.
  2. Pair to HE then to Home.
  3. Paid to HE then use bridge to Home.
Personal preference.. It really makes no difference.. I wouldn’t go the bridge route though since Matter is directly supported on both
Regarding the OR button on the Matter pairing. I noticed it was back over the code field with the latest update. Then realized it had to do with how wide my browser window was.
That ikea outlet is problematic, we don't know why at this point, we are looking into it
