Cannot write to fuel streams
I have a Webcore piston that should be writing to a fuel stream. When I look at the log for the piston it shows an error but I don't know what the problem is:
+526ms ║║Error executing virtual command [].addToFuelStream: (406ms
I have the Fuel Stream app installed. Is there something more I need to do? I know fuel streams stopped working years ago on the ST platform but was hoping they worked on HE. Thanks for any help anyone can provide.
This was an unimplemented command
the command is 'Append to fuel stream...'
Pushed an update to remove the unimplemented command.
