Cannot set null variable to a value in Rule Machine variables page
@bravenel maybe you can assist me on this please?
I have some variables which have ended up reporting "null" in the variables manager page. For example, like this...
They had values driven via a rule in RM from a weather device that stopped working so maybe this is how they ended up with null values. Anyway, if I try to now manually set their value I get the following error message:
Would it be possible to override this error and still allow a value to be set please? Otherwise I guess I have to nuke these variables and start again?, which is a pain because they are referenced elsewhere.
Here is the rule that sets these from the weather device (which is now working fine).
However, if I try to edit this rule by clicking on the actions, I get this error message...
Can these variables be rescued somehow?
Your firmware version is?
It's not at all clear how null ended up in that in the first place, as the hub will generally not send an event with a null value. Whatever driver you are using needs to be fixed.
As for recovering RM, I can see where the problem lies, and clearly RM was not expecting a null value. I've put in a fix for that. So one option you have is to wait for the next release, and then it should allow you to edit the value.
You could try creating a rule that does nothing more than set the value of that GV, to fix it. I don't know if that will throw an error or not. If it does, please post a screenshot of the logs for it.
Thank you.
Just tried that. No error returned in the UI when running the actions. However the variables remains null and I get this error in the logs.
Will wait for the fix in the next release.
Cheers.
Yeah, now that I think of it. Setting a decimal GV wants to round it to some number of decimal places, and that's where the multiply is coming from.
