Cannot edit any "IF" statements in Rule
I have a particular rule and I am unable to edit any of the “IF” statements. When I open one to edit, the edit fields do not populate (See below). Other rules work fine.
Open the hub Live Logs in another window and then click the into the rule to edit that "IF". I suspect an error is being thrown.
Have you tried opening Rule Machine and fixing broken rules?
There’s a ‘find broken rules’ button, but I’ve never seen a ‘fix broken rules’ button. Did you mean the ‘Update all rules’ button?
I meant find broken rules, and then editing each one to fix it.
Yes, it found no broken rules.
Thank you for the suggestion, but I did not see any errors in the output.
Well, nothing else worked, so I restored a backup and this corrected the problem. Had to repeat some programming, but at least it is working now.
