Cannot connect to or find hub
It was working yesterday, before I shut off power to the room with the router/hub for some electrical work. Now, I can't connect to or find the hub. No LED indicator lights are on.
Thanks in advance for any help!
does it have power?
It's plugged in with the supplied adapter. I suspected that it was not working and grabbed a USB power bank with no difference in results.
well I had to ask... If there aren't any lights at all then possibly fried chicken?
I was thinking it might be, but it was working last night and it's only been connected to the provided power supply, so that seemed unlikely. Would support replace it?
Possibly... dunno @bobbyD can answer that or you can email them.
Are you sure the power bar or outlet near the hub is working? I know you tried a Power Bank with it, but something doesn’t add up. Maybe your power bank isn’t delivering enough amperage. Many of the less expensive power banks do not actually deliver the current they claim to.
If moving to another outlet that you are sure is working doesn’t yield results, do you have a phone charger that delivers at least 1 amp you could try?
The router is also plugged into the same power strip. On further inspection, the LED seems to be a very dim blue, but I can only see it in the dark, not even in the dim closet light.
Sounds like your hub is either fine and the LED isn’t as bright as it was when you first got it, or the power supply is possibly defective and not delivering full power.
If you still can’t log into the hub, try a different power supply, but make sure it is rated at 1 amp minimum.
Also... did you have a DHCP reservation setup in your router? If not go through and check your ip listing/devices in the router because with a full power off the IP may have simply changed.
Good point. @jpnichols9, can you find you hub at portal.hubitat.com ?
No, it doesn't show up in the list there.
When I first started having issues, I assigned the IP to my hub's Mac address.
