Cannot connect to hub on 10.x IP
From this post: ‼ READ FIRST - Before Posting in Get Help
Answer these questions to the best of your ability.
All Hub Issues
  • Model of Hub
  • Platform/firmware on hub
Connection / Goes Offline
  • How is it connected to the LAN?
    • Ethernet / Wifi
    • Static IP set on Hub or DHCP
    • DHCP Reservation set on Router/Server?
  • How is Hub being powered? Supplied power block or other (explain)
  • Brief explanation of network topology.
Also, what IP do you expect it to have? What is the DHCP range of your network?
Does the Starlink system have any sort of built in router or is just a modem?
