Cannot connect to hub on 10.x IP
Please check this post for some tips and info that should be provided with your question:
-- ‼ READ FIRST - Before Posting in Get Help
Also, unless you have the EXACT same setup as someone in the other post you originally replied to, we would need to know much more information about your network (see the post I linked above for what info is needed).
