Is this intentional? And if so, is there a way to make this call w/o create my own API endpoint application?
The reason I need this, is that Life360 is severely broken. I have already added a refresh trigger to force refresh the life360 link, but their application is constantly unloading on my iPhone, and they do not respond to requests for support.
So, to build a better mouse trap, I created a Siri Shortcut that reports my presence back to Hubitat. Using Network (wifi) detection and Geo Fencing, I determine if my phone is present or away, and it seems to be rock solid -- except that I cannot change the state of the virtual presence sensor.
I found another topic from 2019 (I think it was) where the messages said support was being added to maker API back then.
I have on occasion used a virtual switch with presence - switch on sets presence to present, etc.
Virtual Switch with Presence
* Virtual Switch with Presence
* Licensed Virtual the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
* 2021-01-03 thebearmay Original version 0.1.0
static String version() { return '0.1.0' }
metadata {
definition (
name: "Virtual Switch with Presence",
namespace: "thebearmay",
author: "Jean P. May, Jr.",
importURL:"https://raw.githubusercontent.com/thebearmay/hubitat/main/dashVariable.groovy"
capability "Actuator"
capability "Switch"
capability "PresenceSensor"
command "arrived"
command "departed"
preferences {
input("debugEnable", "bool", title: "Enable debug logging?")
def installed() {
log.trace "installed()"
on()
def updated(){
log.trace "updated()"
if(debugEnable) runIn(1800,logsOff)
def on() {
if(debugEnable) log.debug "switch on"
sendEvent(name:"switch", value:"on")
sendEvent(name:"presence",value:"present")
def arrived(){
if(debugEnable) log.debug "arrived"
on()
def off() {
if(debugEnable) log.debug "switch off"
sendEvent(name:"switch", value:"off")
sendEvent(name:"presence",value:"not present")
def departed(){
if(debugEnable) log.debug "departed"
off()
void logsOff(){
device.updateSetting("debugEnable",[value:"false",type:"bool"])
