You want these. That said, you will also want either an inovelli or or zooz switch/dimmer to control them as they have smart bulb modes. If you use a regular switch with them you will have problems.
https://www.amazon.com/BENEXMART-Zigbee-Downlight-Contorl-Directly/dp/B08QHLNV8C?th=1
Also Welcome to hubitat! Take a look at this thread as well.
Just throwing this out there. It may or may not be a help and I'm sure many others will contribute to this thread. Here are a few things to start you off.
Z-wave Devices:
1: You do not need Wink/ST/Vera etc. to exclude your existing z-wave devices. Hubitat can do the exclusion for you. (Make sure you turn off your old hub first!) In most cases this is sufficient before pairing. Sometimes though you may need to factory reset the device. Non Plus z-wave devices may have to be included/excluded …
