Canless RGBW recessed light recommendations - 2025
We're getting ready to do a kitchen renovation and I'm looking for current advice on the best canless RGBW lights to pair with my Hubitat C8 Pro. I'm open to Z-Wave, Zigbee, or Matter over WiFi solutions as long as there is a local Hubitat integration. I'd also be willing to consider Thread if there was a good reason to choose it over the others, but otherwise want to avoid anything that requires a separate hub or where a separate hub is recommended (i.e. Philips Hue).
We may upgrade a few can lights in the next room that currently have Sengled Zigbee bulbs in them to make everything match, so in total we'll probably need between 10 and 16 lights.
What lights are people using that they're happy with?
Hue. Or for much less Govee.
Hue. Expensive , but they just work. But yes, a Hue hub is recommended, but having another hub was worth it, for me at least.
Some data points from my testing
Feit WiFi total junk don’t waste a penny on these
Lightingside matter / WiFi are ok colors are not consistent model to model. Bulbs loose config every 4-6 months and a repair is required. I am still tracking this down this problem. They are cost effective but the nonsense is making me dislike them quickly
HUE the retro cans are great, the candelabra bulbs are just stupid expensive but i never had a single issue with either of them. I originally had them natively paired with hubitat and then went back and used the bridge instead. The hue bridge allows for simple scene creation, pre-canned holiday scenes it’s just better overall. It also manages the bulb firmware. All scenes map to hubitat the integration works very well
I have some third reality zigbee bulbs coming today I am going to test.
Good friend has had success with Lifx
My 2 cents
Obviously I am a bit bias but Govee has a tone of options. That said not all of their devices are at the same level. I believe they still have some room for improvement with the canless lights.
My main issue is with any new device that doesn't have a local lan control. Sometimes it makes sense, but not most of the time. I am trying to get a pair of bulbs that I believe support MATTER and Govee's LAN API. So my point is if you look at Govee, make sure the device is able to do LAN API to meet your ask. New devices are constantly coming out with better support as well.
As far as I know govee canless lights do not support Lan control at this time.
Lighting is important to me. Given a choice of can VS can less I always go can. The reason is the recessed spot effect is premium. A disk light with no spot or direction that you can see works fine for general lighting and where you have limited space below pipes and joists, but it's just not the same. Also, there are lots of choices for bulbs and they are easy to understand and replace.
Thanks to all for the replies. The TLDR is I am going with these Halo / WiZ lights from Home Depot: https://www.homedepot.com/p/HALO-RL-Dual-Zone-4-in-Smart-Wi-Fi-Canless-Integrated-LED-Recessed-Downlight-Connected-by-WiZ-Pro-RLWZDZC4/334557796
For those interested in the details, I was going to bite the bullet and get the Hue bulbs and a Hue hub, but they I discovered that the canless (non-retrofit) lights don't come in a 4" size. The 6" size isn't going to work for us in the kitchen, because we want multiple light sources to avoid shadows, and the 6" lights would look too big and be complete overkill in the quantity we want to use.
Despite the recommendations for Govee in this thread, there are some reviews online showing that they may have some quality control issues with those lights (multiple reports that the spring clips that hold them in the ceiling just pull out of the fixture) so I decided against those.
After researching other 4" alternatives, I ordered a set of matter-compatible LiFX "deep baffle" recessed canless lights from Home Depot: Error Page (I don't know why that link shows "Error page" in my editor... it works in an incognito browser window).
These seemed attractive as they have the recessed spot effect that @JumpJump mentioned, and come with magnetic trim pieces that let you change them to black trim or to a flush appearance with a diffuser covering the bulb.
In addition to needing new kitchen lighting, we also wanted to remove the 6 cans in our TV room that had Sengled BR-30 RGBW Zigbee bulbs and replace them with canless lights. The bulbs in those cans stick out past the ceiling, and they produced a lot of glare when they were set to white and anything but their lowest dim levels. The cans we have are an odd almost 5" size that won't accept a retrofit-type canless light, even when they say they are 5"/6" compatible. I tried several and none fit, so the cans needed to go.
Before the LiFX bulbs arrived, we decided to pick up one of the Halo dual-zone lights and one of the Halo 'slim' lights (https://www.homedepot.com/p/HALO-HLB-4-in-Color-and-Tunable-White-Slim-Canless-Smart-Wi-Fi-LED-Recessed-Downlight-with-WiZ-Pro-HLB4069WZRGBWMWR/324821250) that were in stock at the local HD store. The slim lights have the advantage that you can mount them anywhere, even under a joist/rafter. From looking at the website, I really thought the dual-zone lights looked too busy and I expected they would look gimmicky in real life. But we figured we'd give them a try for the TV room since they have a night light feature using just the outer ring light that seemed like it might be good in that room. We figured they were way too busy-looking for the kitchen, so we were evaluating dual-zone for the TV room and the slim light for the kitchen.
I pulled two of the cans in the TV room and installed the Halo lights. After testing them, my wife and I agreed that the slim light with its flush appearance caused way too much glare. It was worse than the old bulbs. The dual-zone lights were much better. I attribute that to the contrast, especially at night when the room is only lit by the bulbs, between the illuminated lens and the ceiling (which is painted white). The slim lights really don't throw any light upwards, so there is a stark contrast between bright bulb and surrounding ceiling. I think that hard contrast is what makes them unpleasant to look at, even indirectly.
On the other hand, the dual-zone lights first have a slightly dimmer area where they are illuminating the interior edge of the fixture, since they're recessed maybe 1/2 inch. When viewed from an angle, the recess hides the nearest edge of the bulb from view. Then they have the ring light that is much dimmer than the main bulb, making a transition from bright bulb to dimmer ring. Add to that the fact that the ring light casts some light upwards towards the ceiling, making for another transition from dim ring light to even dimmer glow on the ceiling. The overall effect is much better.
Once I realized the Halo/WiZ lights have a really great integration to Hubitat using the built-in Wiz integration, that sealed the deal. We're going with the dual-zone lights everywhere. We returned the LiFX bulbs to HD without ever opening the box.
Here are some photos. The outer-most ring in these photos is a "goof trim ring" that we needed since the holes from our cans were just a hair bigger than the outer ring of these lights. Without the extra trim ring you wouldn't see as much of a shadow around the light. We won't need those in the kitchen, so the lights will look a bit smaller in there.
In this image you can see how the bulb is slightly recessed into the fixture.
These look rated at 700lm. Are you finding them bright enough at 4000k white?
We have 6 of them in a 16' x 12' room with 8' ceilings. I just set them to 4000K @100% and they are VERY bright. My wife commented they would work as task lighting at that level and asked me to turn them down. In Room Lights I have some presets none of which are above 75% for these lights. In the kitchen we're going to use 8 of them in order to get task lighting over all the right areas... I doubt we'll ever turn them up above 50 or 60%.
Nice. Sometimes the lumen numbers are gamed. Those are interesting lights. I've never seen the dual ones in person.
Interesting that these can also do 0-10v dimming. Not sure I've noticed some of these smart cans doing that before. Maybe it's common. I like that for managed spaces or for older folks.
I don't see the 0-10v dimming in the spec sheet. I only see where it says not to use with a normal dimmer.
Home depot specs could be wrong.
I think they are. The page links to the manufacturer spec sheet. No mention of 0-10v dimming.
