@bravenel ,
Does Cancel Pending Actions when Required Expression Becomes False also cancel ongoing 'Fade dimmer over time' and 'Change color temperature over time'?
During the day (global hvLrLightMode = 'Automatic') the Color temperature changes and is tracked by global hvLrCT.
When hvLightMode changes to something other than 'Automatic' will the Change color temperature be cancelled?
This makes sense from a programming point of view. Instead of finding and maintaining everywhere global hvLightMode is changed away from 'Automatic' and this rule's actions needs to be cancelled it can be done once here.
That bug was fixed: the fix was to make the number entry a required input. In other words, the UI should not allow you to leave that page without providing the value. However, I just discovered that the UI is not enforcing the requirement. We are looking into it.
If you don't want to set a value, don't turn on the option to set one!
I am using the option 'Fade level with Temperature?' OFF. Therefore the UI should not be enforcing a value. However you are right, with that option ON the UI should enforce a value but is not and is allowing a null value. My issue is that the code is failing on a null coming from the option turned off.
I am using. Chrome and sometimes MS Edge Canary. Both are acting the same.
