Is there a way to restart an installed application without rebooting the hub or altering the applications code.
In short I would either like to create a button or timed rule to restart a single application without rebooting the entire hub,
I'm asking because I have an app (echo speaks) that appears to crash daily and the only temporary fix I have to date is resetting the hub. Because I don't have a fix for this I need to figure out a temporary work around.
I would suggest you take this up with the app author. In general, apps should never crash. For most apps, crashing is a temporary condition, but it depends on how it is setup. If the crash leaves the app in a corrupted state, you should be able to get it going again by opening it and hitting Done.
This topic has been marked solved by the community and subsequently closed. For further discussion on this topic, feel free to create a new thread under a different category to continue the conversation.
If you are logged in, click [HERE] to get started.
