I have a weird rule machine question to see if this is even doable?
I have a recessed door switch on my master closet door. The master closet has a dimmable switch and dimmable LED light.
I have a rule that turns the closet light on when the door is opened and it turns the closet light off if the door is closed or if the door is left open for 20 minutes (in case my wife didn't shut it all the way :)) This rule works as intended very well.
Here is the part I can't figure out. Taking that same rule logic, can I dim the closet light to say 20% when the closet door is opened only between the hours of say 11:00pm to 7:00 am? Outside of those times, it would be full brightness.
The reason for the weird request is that I work for the railroad and when I get called to work for 3:00am, I would like the light to not be full brightness while I am getting ready as to not disturb the wife too much.
I'm figuring maybe two separate rules?? Any help would be greatly appreciated!
Scott
