It seems I keep losing my hub. I tried find hub but N/G. I reboot the hub and all is well. This problem just started a few days ago. It has happened once a day for the last 3 days. I have not added anything new. I have a static IP and DNS is set to 1.1.1.1 on both EH (C7) and my router.
Again when I reboot my router I can then find the hub.
Oh, don't do that on both.
You should set your hub to Dynamic (DHCP) and the router reservation for your IP address of the hub.
OK, I reset to Dynamic (DHCP) and the Hub IP was already set. I'm hoping this will solve the problem.
Also make sure nothing on your network is set to use jumbo frames. If you've had to repeatedly unplug your hub to reset it, I would recommend doing a soft reset on it (or simply restore to yesterday's backup) to ensure that your current database isn't corrupt. (backups are cleaned during the backup)
Thanks for the information regarding backups being cleaned. I did not know that. Hub seems to be ok now, but I'll give it a few days and see.
