I went to add a sensor today and can't log into my Hubitat. I rebooted the router and hub and nothing! all my animations are working i just can't log into the hub....Help
Have you done DHCP reservation on your router for your hubs mac/lp address?
If not that is something you should really do.
Also have you tried https://portal.hubitat.com/
Can you see your hub here and is the ip address the same or has it changed?
It has changed and sorry I am not the best with this I didn't do a DHCP, I don't know how or what it is
Can you log into your router?
The password may be on the route somewhere.
Do you know what type of router it?
Have you got the user manual for it?
I have a nighthawk R7000 router
https://www.manualslib.com/manual/582801/Netgear-Nighthawk-R7000.html?page=16#manual
https://www.manualslib.com/manual/582801/Netgear-Nighthawk-R7000.html?page=32#manual
https://www.manualslib.com/manual/582801/Netgear-Nighthawk-R7000.html?page=101#manual
Log in to your router and then reserve the IP address of your HE hub as per the last link Iabove.
