Would like to place the hub in a place where i have no power outlet only ethernet cable. I can provide up to 802.3bt (60w).
Yes, you just need a PoE splitter, example: https://www.amazon.com/UCTRONICS-PoE-Splitter-USB-C-Compliant/dp/B087F4QCTR
Hub only needs 5v at 1 Amp to function.
The ethernet jack on the hub does not support PoE itself.
