Can I use different Hubitat Elevation models to build a mesh?
I have a C-7, and need to add another hub to get better coverage (I added a shop next to my house). Things are working but could be better. Can I add the new C-8, and run both the C-7 & C-8 together to make a better mesh, or do I need to get another C-7, or do I need 2 C-8 to make it work better?
Yes, you can mix and match different Hubitat Elevation models when using the built-in Hub Mesh:
This topic has been marked solved by the community and subsequently closed. If the issue persists, or for further discussion on this topic, feel free to create a new thread under a different category to continue the conversation.
If you are logged in, click [HERE] to get started.
